Why is there a slider for material scaling, but not for stretch, offset or rotation? How to map a google maps color map to a custom height map when you cannot adapt it?
Hi there. Just to be sure that I comprehended your query, do you mean that you want to insert a Google map image and then proceed to adapt its terrain according to its exact height (highs and lows)?
no, it’s the other way round.
i made a terrain with a custom height map from google and then i want to apply a custom texture map to it (in this case the google maps image the height map is from)
Hi there, currently we only support black and white terrain maps and we have yet to support the feature that you are currently seeking. Thank you so much for your understanding.
i used this
for making the terrain and it worked fine. then i wanted to texture the terrain with a custom material map. this worked too (as seen in the first screenshot)
BUT apparently it is (yet) not possible to edit (rotate, offset) the applied texture map apart from scaling.
or ist it and i just did not manage to find this function?
Hi there. Thanks for sharing the height map you used. We have yet to add the modification of the texture map. Perhaps we can develop it in subsequent releases. I’ll be sure to convey this matter to my team. Thank you.
