Terrain error
After creating a site or terrain and saving the project, the terrain disappears when the project is reopened. Although settings—such as painting data—remain visible, the actual terrain geometry is missing.
Even after deleting and recreating it, the same issue recurs upon saving and reopening the project.
It is difficult to upload the project file due to size limitations.
Hi @anishop77
Can you please share the following by generating a google drive link or wetransfer link containing these files:
  • Can you please also confirm which D5 Render Version you’re currently running? You can check it in this portion
    2.11 Build Version
  • Additionally, where is this file located, is it in your Local C/D drive or perhaps in a cloud storage/shared network path?
Here is the Google Drive link.
Hi @anishop77
Please edit the accessibility settings.
I have modified the access permissions.
https://drive.google.com/drive/folders/1EH5ub7hnIQS9EJq4bWjEYZI7EYE-U1TX?usp=sharing
Hi @anishop77
Can you please try this version?
The same issue occurs with version 0758.
If I create a new terrain, save the project, and then reopen it in D5, only the terrain settings remain, while the actual terrain model is missing.
Hi @anishop77
Got it. We’re currently checking the logs and the D5 file that you sent. I will update you as soon as possible.
Hi @anishop77
Can you please clear/delete this folder then try to use the terrain feature again?
  • Completely Close D5 Render
  • Go to your Workspace folder
  • Delete assetTerrain folder which is found in D:\D5 WorkSpace\content
  • Reopen D5 Render then try to use terrain again and see if the issue persists.
I tried deleting the Terrain asset folder and creating a new terrain, but the same issue persists after saving and reopening.
Okay got it, please check your forum inbox we may need to check your device.
