Taking images of the scene every 10 degrees in an orbit mode
Folks,
I am very new to this software. I have a requirement where I have to take photos of a scene every 10 degree while my orbit centre is fixed. Is this possible in d5?
thanks
Harsh
That is, you can do it this way, have the camera fixed and rotate your project by unlocking it in the drop-down menu on the left where the name of your project is, then on the right you can rotate it in Z every 10° and take the image.
But when you synchronize your project, make sure that the XYZ axes are at the center, those of the graphics program.
I hope you can make your own images this way
If you can’t, there is the video function that revolves around the object, you just have to import them in JPG in a 4K or 8K format, to have good quality
Hello. I think a combination of 360pan templates and sequence export of videos can achieve what you need.
I made a simple demonstration video and you can refer to it.
Hi Ricardo, How can i use the Video function that revolve around the object? I want to rotate around an apartment complex. How can I tell the video function to lock on and rotate around this aprtment?
thanks
Ciao, le funzioni delle telecamere sono alla tua destra, ci sono diversi movimenti ce anche quelle a 360°, io uso pochissimo la funzione video, faccio solo render. il questo caso basta applicare la funzione 360° e dare un tempo ai due fotogrammi.
Buon lavoro
Hi, the camera functions are on your right, there are different movements including 360° ones, I use the video function very little, I only do rendering. in this case just apply the 360° function and give a time to the two frames.
Good work
Hi Ricardo,
Though I dont understand the language, thank you for your prompt reply…
Also, Just got it working… thanks
Sorry, I was in a hurry for work
No worries. thanks a ton… got it working… works like a charm
