Hi, I see that on the system requirements, most AMD 7000 series GPUs are not listed under supported GPUs except for the 7900XTX. I just wanted to ask that if I were to purchase a 7000 series GPU like the 7900GRE or XT, would I still be able to use D5, or is it completely unsupported? Or would people recommend getting a Nvidia GPU instead for the better raytracing support?
7900 GRE should be supported to run D5. However, comparatively speaking, there are more graphics card options from the RTX series to run D5 Render. ![]()
You can visit this site to compare the data of various graphics cards provided by D5 users, which can provide additional reference for your decision-making.
https://benchmark.d5render.com/result
Hi.Checked the requarements and I’m using a laptop with intel Arc A370M.
Installed D5 render application and launched it.
It will just stop at the step “Intialiting and please wait for a while.”
Anybody have the same issue?
It is disappointing that the programme works with gtx1060 and 1660 but not with gtx1650 graphics card. Many people cannot use the programme they downloaded with enthusiasm because of this situation. Developers need to make arrangements and take action on the subject. While there are many competing rendering programmes on the market, you are losing customers in this way.
Hi irem.14399, I agree with what you said. When a company produces and evolves with this speed compared to other rendering engines it is only to be praised. But it is leaving out the problem, it has been for a long time, the questions and problems of users on the interface between the program and the system. It is not enough to read their directive of the various graphics cards and their power, starting from the GTX up to the RTX. There are users who have faced expenses to comply with their directive, without encountering this inconvenience that the program does not work. I understand well that behind it there is an intervention team on the web, to stem and support all users, and they are fantastic at their work, they know that we waste our blood for a delivery to our customers.
I am one of the lucky ones, that the D5 engine did not give me any of these problems, at the beginning when I started with D5 it was 1.3, and to make it work I bought a 16G GTX 1070 laptop, at the time there were cards GTX graphics and then RTX came out a few months ago, the program immediately adapted to these new cards which gave advantages to the realistic image.
I tell this thing because among the many questions from users is the team’s answers, regardless of the fact that I am not a technician, I think that the D5 interface with the various operating systems that differ between various computers and graphics cards is memory frequency , the program acts differently for each one without considering that they should overcome this type of approach to make it work with all the various situations, that is, a single key that opens, but at the same time with the evolution of the program, simply adding it to that key as a container.
I repeat, I am not a technician or a programmer, but the idea is not easy to create if there isn’t a team of programmers behind it.
Hi, I’m trying to install but I don’t quite understand why it doesn’t let me run the software. Could you please check?
Thanks
Hi there. I apologize for the inconvenience this issue has caused. Usually, a greyed-out row means that your graphics card driver is not updated. You may want to update it in your NVIDIA GeForce Experience application or directly through NVIDIA’s website. Thank you.
Hi there. The minimum requirement for D5 Render to run D5 Render using NVIDIA GPU is GTX 1060. Although the GTX 1650 was released around 2019, compared to the GTX 1060, it still falls short in terms of performance (the 1650’s predecessor is the 1050, and the 1060’s successor is the 1660). Many people assumed that the 1650 would be better since it came out much more recently than the 1060, but to their surprise, the latter seems stronger despite being released in 2016. Hence, D5’s minimum requirement starts at the GTX 1060 graphics card. You can check this link, which contains a side-by-side comparison of the two graphics cards:
GTX 1650 vs GTX 1060 Test in 9 Games
Thank you.
Hi guys, how are you doing?
Is d5 running if i buy a
Hi @a00832623
This specific section of your System Information is greyed out. please update your Graphic Drivers via the NVIDIA App, or you may access their official website. Download The Latest Official NVIDIA Drivers
How is it possible that a graphics card from the 6000 series for AMD and 1060 for Nvidia is required as a minimum requirement to use the program? I have a 5600xt, which is superior to 1060, and still, I can’t use the program.
It seems like AMD 5600XT lacks ray-tracing support which is very important since D5 Render is a GPU-based renderer that is built on DXR and ray-tracing technology.
WHY?
Hi @huj7103
Please check the prompt that is evident on the bottom part of the pop-up:
- It seems that you need to upgrade your Driver Version. You may upgrade it via the NVIDIA App and please avoid the 576.02 Version
ty so muchhhh
Thanks
Your driver needs to be updated. Please check the note or prompt below System Windows
no señor, no es compatible. recomiendo minimo 2060 super
