Hi D5-Team,
Can you please make it possible to set more than just 1 on the normal map slider? The normal map strength of 1 is often still too low. Thanks
best regards
Hi D5-Team,
best regards
I thought I was doing something wrong, so I’m glad to see it’s not just me experiencing this issue ![]()
I have another question and idea.
You can invert the normal map with the “inverted” option. But it’s the same as changing from -1 to +1.
“Inverted” option should invert the green channel so you can change the OpenGL normal map to DirectX normal map (which D5 requires).
A better way would be to automatically switch OpenGL maps do DirecX in D5. Is it possible ?
best regards
