Hi, is there any way to set D5 Render window to snap when using multitask/split screen on windows? I’ve bought a single widescreen monitor instead of two 16:9. I work on Revit.
Try opening the window you want to split first, then press the keyboard shortcut Windows key + left / right arrow
Didn’t work ![]()
Can other applications be snapped normally? And is this only occurring to D5 Render?
You may want to check out these links:
- (320) Easily Split Superwide Screen For FREE!!! - Microsoft Power Toys! - YouTube
- Window snapping on ultra wide screens - Microsoft Community
Thank you.
Only on D5 Render. Other applications can be snapped.
It seems like D5 Render cannot be ‘snapped’ when multi-window layout is used, even in a 24-inch monitor. I think this is because D5 Render functions like similar GPU intensive games which are only available to be minimized and maximized.
- I think a third-party application may help. You can try installing the Microsoft Toys. Microsoft PowerToys | Microsoft Learn
