I am having issues with all hot spots showing in all views. also having the hotspots being named ‘Untitled’ even when I rename them.
Hi @abarshinger
Sorry for the inconvenience caused. Could you please confirm the following:
- Which D5 Render version are you currently using?
- Does the issue happen in all Spatial Tour projects or only in one specific project?
- When the hotspots appear too bright, does it happen only in the preview/web tour, or also inside the tour editor?
- Did you recently publish or re-upload the tour to D5 Cloud / MySpace after renaming the hotspots?
Also, just to check one common case: are multiple team members editing the same tour? Sometimes the project can be locked, or changes may not be updated correctly when edits overlap.
