spatial tour hotspot and 3D 2D problem
The hotspot disappears or changes location when clicked, it doesn’t work, and it stays on a dark 2D/3D screen.
2-3 farklı projede denedim, aynı sorun devam ediyor. D5’in yerel mekansal tur kılavuzunu kontrol ettim ama bir çözüm bulamadım.
I open the project in VR, but the hotspot doesn’t show up at all, and the gallery menu doesn’t appear either; I’m stuck in just one area.
I’ve been experiencing this problem for 4 days. The 360-degree panoramic tour works flawlessly, but I’m having trouble with the spatial tour. I urgently need help; I will pray for everyone who helps me.
Hi @berrualakoc
By chance, were you able to reach out to us via support email?
Can you please send us the following:
https://showreel.d5render.com/personal-krpano?directory=https://usa.asset.d5cdn.com/tourProject/pano_roam_1781098139938_3535236/&tourId=2064701797686620162
If you provide your email address, I will share the video.log recording and the project with you.
Hi @berrualakoc
Thanks for this. Please generate a link using Google Drive, WeTransfer, OneDrive, or Dropbox that contains the video recording. Then you may send it to me directly.
