**Theme:**SOFA’ EDRA CIPRIA
I announced to you a couple of hours ago that the grass model inserted into the Edra sofa with the brush was successful. It was enough to navigate around a bit and take the grass material with the dropper and replace both the color and the texture, erasing the others for the PBR, after which insert your map giving the way to move from leaf to fabric. In this case a pink velvet fabric, and then start the AI for the PBR.
This is the result, albeit a bit cumbersome:
Hi Riccardo,
I suggested it a long time ago. This function is really missing. And I think it is relatively easy for the D5 team to implement since the grass material already exists. Tnx for testing…
Hi Albareus, I read your post, I literally agree with you. D5 takes a moment to do what I did in a couple of hours. with the grass model. But I’m waiting for different things from D5 group, not only what I did, but also the night environment part like starry sky with moon, which I did by myself with D5 program is different sources.
Let’s hope for the next update.
I agree. I’m used to working with Cinema 4D. Some things are a lot easier here. There are still a lot of small things in D5 that could be improved. I’ve already reported a few improvements and hope that some of them will be implemented in the next updates.
regards
