Slow render
Hello, today i start rendering of my last model, but is shows me reamin time more then 1h . I never seen same slow rendering with D5? What may would be problem? Any suggestion?
The estimated rendering time is calculated dynamically based on the progress of completion and the time already spent, and the time may show a high front and a low back, so you can wait until the rendering is completed and see how long it took.
The rendering speed is related to the complexity of the scene (specifically the number of faces of the model, the number of plants and lights, the accuracy of the mapping, etc.).The more complex the scene is, the higher the video memory and memory usage will be and the longer the rendering time will be.
Please show us a screenshot of the scene information ( Click on D5 menu bar - View - Show information statistics ) and the video memory and memory usage during rendering to confirm that the final rendering speed is within expectations.
Also, you can refer to D5 Benchmark Tool and compare rendering time with hardware of the same configuration to see if the rendering speed is within the normal range.
