HI. I am also facing this problem often. while rendering shadows of some trees gets shifting. I have attached the screenshots of couple of frames. Please check that.
Hi mate, did you open the “realtime” during rendering? the shadows are shifting probably because of the wind. you can close this effect and try again. If the problem still persists, you can close the dlss and try again.
hi. its not because of wind cause only these two objects are giving problem and it happen earlier also. This is happening in final video after rendering and in realtime as well. if you want i can send you the video as well.
i’ll try this again by closing dlss and will revert back to you
Hi mate, if the problem persists please send the video to us for troubleshooting. support@d5techs.com
