Hello
In the recent D5 update, the section plane fill doesn’t seem to work in video mode.
In fly mode and editing works fine but when i switch to take a video with the section plane fill on it turns off.
Hello
Hi @firassalihofficial ,
The criteria for determining the filling of the section are based on the triangular index of the model, it will have a clockwise and counterclockwise direction, based on this we judge whether it is filled or not. If it is not filled, the most likely reason is that the geometry at the section is relatively complex nested, which leads to early filled. We suggest you merge some models with a lot of resurfaces and see the results.
And currently, we do not support this function in video mode. It maybe appears a pop-up window on the screen.
Maybe if it could be enabled when rendering animation as image sequence no?
Hi there,
Even exporting the video as an image sequence will not include the section fill color since we do not support such a function for now. Thank you for your understanding.
