Sea and Ocean
Hi guys, I’m working developing the 3D perspectives from a house in the beach and I need some tips about how to make the ocean in D5 render
Anyone here worked with something similar?
I once made a video with D5 render and SU “Beach and Sea”.
Maybe it will help you. Give me a message,
if you want to know how to do it.
Video QR-Code
qr-code (1)
Can you guide me to the tutorial?
would be nice if this will be used for the sea/ocean
Hi! Hoping the next release version must try to do additional effects for water like foamy accumulating from the edges to make it more natural and realistic. Thanks
water foam
Also automatic wake for boats. Or as a 3d asset.
Thank you for your advice!
we need some thing like this for a lot of projects … hope that
https://www.unrealengine.com/marketplace/en-US/product/beach-wave-water
Thank you again. We will improve the water performance.
This post was flagged by the community and is temporarily hidden.
Any update about ocean material?
is there any updates aout this? thank you
Hi there,
Is there a possibility to add roughness option to water material ?
For large scale water like a sea or a lake, I achieve better results with custom material and normal maps than with water material. The only thing is that water doesn’t move in that case which is bad for animation… and we don’t have all the transparency and depth settings too.
Here are screen shots of the 2 cases with material settings on the side.
Thanks D5 team !
(If we could have foam assets or decals video assets too we could achieve awesome seascape results, but that is discussed in another topic too)
The worst water ever.
It is impossible to achieve the look on those ref below with the current water material options. A roughness slider option would definitely help.
D5 Needs a water emulator, Lakes, pools and sea cannot use a ( texture ) if you have serious purposes. Waves, foam, maybe splashes…are needed. Beach, ocean, with maybe some real settings.
Exclude objects from snow and rain, and clouds with reflection of sunlight. ( still white in sunsets )
with creating ocean you can add waves on the beach and sculpting terrain it will be a superiority in d5 render
Any news about this?
Water is already mediocre in d5, yet it’s not about giving us an ocean material.
A global solution of generating level of sea with waves and foam that reacts to rocks or beach would be great.
I mean you’re overall better for sure than Lumion, that I was using for years, yet you’re missing some really important things that it has like real displacement, ocean, path tracing.
Hi there, just adding my wishes to this chain too. I design boats for a living and have migrated to D5 for producing the interior renders due to its superiority in this realm. However, when it comes to attempting exteriors, an ocean material could definitely make a massive difference. More on that, any and all additions to the software that would help support us boat designers could mean a whole new influx of purchasers of the software. I’ve gotten better results using different imported normal maps, this image here though is with the standard water in D5 as best as I can make it like the ocean. Wake profiles would be an absolute dream to have too if possible. Cheers.
