Hi guys!!
I need with a little thing. Suddenly my d5 render has stopped updating my scenes.
For example, I have a kitchen scene and I change the position of the sun, I click update, change to the living room scene and it has changed me too, it does not keep the configuration I had for that scene.
Does anyone know what’s wrong?
Hi there,
Please check if Camera Switch Only is turned on, just turn off this setting and everything will be fine:
Camera Switch Only - When Camera Switch Only is on, the last adjusted exterior and post parameters are always applied when the camera is switched. When the camera is switching, D5 reads the camera position information of the target scene and the current lighting and post parameters.
Even after months of using D5 and reading the explanation for that “Camera Switch only” thing several times, i find it still confusing.(others too, obviously. this thread is not the first one about this)
I would prefer simple “copy/paste (or save/load) scene parameters”-buttons
Thanks a lot. Solved!!!
There have been some incidents where this setting has been turned on by mistake, and it’s not easy to find out you have it turned on, I have fed this back to our product team and will re-evaluate the feature and the real user need for it, thanks for the feedback mentioned above. ![]()
