How to frame scene images with correct angles without deforming images with greater depth of field?
Hi mate, you can try to increase the parameter of “Blur” and check the result.
Also, the distance between the camera, and front and back objects may affect.
Hello, Bruce. Thanks for the reply and the magnific images.
What is difficult for me is managing, not to distort the images in small interior spaces and with perspective angles. I’ll try to work with focused objects and f8.
Hi, you can try to use the camera clipping plan to avoid the narrow space situation and increase the parameters of focal length.
Ok, thank you so much.
I will try use this values for better results.
