When a group of trees are selected how do you select the entities within to remove them from the scatter. Currently you cannot select the scatter entities.
Hi, try selecting the kind of plants you want to remove, then drag the eraser’s Radius to maximum to use the Erase tool.
Hi Oliver,
Thank you for your reply. What I meant to ask was if I forgot the type of object used for scatter, clicking on it should highlight it as it does in Twinmotion. It will make things so much easier.
Is this something that can be implemented in future updates?
Thanks
Ok, I understand now. Yes, we have received much feedback about this, and we are going to figure out a way to do it.
Regards,
Oliver
Marvelous. Looking forward to seeing the implementation.
