Hi, I’d like to know if is there a way to animate a Scatter object. When I select an animation template, the Scatter object turns grey and can’t be selected.
Thank you !
Hi @fchapot
Currently Scatter objects cannot be animated in D5. The Scatter tool is for static distribution only, so it turns grey when animation templates are selected. If you need animation, you’ll have to detach the scattered models into individual objects and animate them separately. Thank you
Hi, thank you for your quick response. Can you explain me how to detach the scattered models into individual objects ?
Thanks
