Scatter Global scaling
In Scatter, do we currently have a global scaling option that affects all plants at once, both small and large? It would be useful to have a single control that adjusts the overall size of all plant instances uniformly.
When you use the ‘new’ Scatter, you’ll see the vegetation list on the right.
You can select each plant type individually and then adjust the scaling for that specific type.
By default, the scale is set to 100%.
Hey,
I’ve got same problem. I would like to be able to change global scaling. Per default, grass is too big compare to the tutorial I see. I would like to change default value…
Hi @mickymx
You can only select one plant type at a time and modify its scale.
Thanks, I know it. But you used a scattering preset with lot of plants, it takes a long time.
And you can’t save if if you are not in PRO version.
A global parameter would be just useful.
Hi @mickymx
Alright, I highly suggests posting it also in Ideas and Requests section. Thank you~
