Scatter fail
Hello, im getting the PRO ONLY logo in the Non pro Scatter options ( only 2 )
Please, dont ask me abot version, machine or etc.
Please FIX IT
Look at the pictures-
If you log back into your account you should be ok
No. The problem is not solved with the re -login
Scatter used meadow 08
Hi there,
I apologize for the inconvenience. Please try to delete the scatter and regenerate it again using the same Scatter Template - Natural Meadows 09 then see if the watermark disappears.
  • Natural Meadow 09 is free and Natural Meadow 08 is not, nevertheless I have reported this issue.
Additionally, can you please send us your log files? Please send it to support@d5techs.com and have it titled “Clov-Forum Free Scatter has Watermarks” if you are unfamiliar with how to generate a log file please follow this link: How to use Support Tool? | User Manual
No, the information you provided is wrong:
The problem is the same .
Hi there,
After checking with our team, we’ve found that this asset is indeed a PRO-exclusive feature. This is correctly reflected in our CN Version. We apologize for the error that caused the PRO designation to be missing in EN Version which has now been fixed. :bowing_man: :disappointed_relieved:
lQLPJxoydk5EnaHM_MzysPR9NfqfcQx7B5JjjMwYDgA_242_252
lQLPJwraWqiP-oHM4Mz8sIFbbv-uaWdwB5JgaGQ6agA_252_224
This is very confusing and is not solving the problem. Now i dont know what is free of what not. Please , can you provide more usefull and acurate information?, For example: Is scatter for free? Yes/ no… If yes…how so? what scatter option can i use?.. This is for now, i will buy D5 license maybe next month.
Thx in advance.
Hi there,
The scatter tool itself is free, you can use the feature as long as the assets that you are using are labeled as “Free” and not as “Pro”. I hope this clears up the misunderstanding and has provided you with more information regarding our scatter tool.
  • Scatter was generated using a Community Version account and vegetation assets used are also accessible in the Free Version.
This is not a misunderstand at all.
Please read and look at the pictures.
Im using scatter grass who are not labeled as pro and im getting the PRO logo ( watermark ) Pictures are attached.
Please provide an aswer to the question and topic presented.
Im still waiting for the name of the free GRASS scatter assets.
Can you tell me?
Natural meadow 09 doesnt have any PRO logo in the thumbnail. And im getting the pro watermark anyway.
@mauroark
As mentioned, Natural Meadows 09 is a PRO asset that was displayed incorrectly, which was rectified and repaired upon reporting this problem. Hence, the reason why there is a watermark when you use it.
  • As you can see, if you check the asset right now the PRO marking located on the upper right of the thumbnail has already been restored.
  • You’ve asked a question regarding whether the scatter tool is free. Please check. Thank you.
Please provide the name of the FREE Scatter assets.
Mi version is not fixed.
Hi there,
Please try to change the “Filter” of your asset library and select “Free Only”, you will see all of the assets that are available for the Community Version
Please send us a screenshot of your asset library with Natural Meadows 09 on it, to confirm if the Pro label is there. This was repaired last Friday, February 14 2025. Thank you.
Please fix it:
Hi @mauroark
No watermarks on my end and Scatter Asset functioning properly. Please send me a screenshot of the scatter in aerial view and a full window screen of D5 Render while clicking the scatter info. Thank you.
