when I save a render file picture it overwrites the previous one. the names are different. if I save the picture file with another name it’s ok. i don’t know
Hello cris, it sounds abnormal and like a bug, but we did not repro this issue successfully. Could you please share more details with us? And can you repro this issue on other scene files?
I created a folder on the desktop and if I save the render images in this folder the files are also overwritten with different names. if I save in another folder it’s fine
Hello cris,
We rechecked the related algorithm, and still cannot repro the issue you met.
For now, if you render a photo and select a target location having a file with the same name, it will ask you whether to replace that file.
And if you use render queue, it will add numbers at the end, so it will not replace or remove previous files.
If you can repro the problem, could you record a video for us for further troubleshooting?
Thank you in advance!
