Rtx 3090 or Rtx 4080
Hey everyone,
I am using SketchUp with D5 render, creating animations and working with big files that take up more than 50GB of RAM memory. While I understand that the 4080 is faster judging by benchmarks and the D5 submitted results, I’m curious would the 8 GB more Vram that 3090 has impact the rendering times more significantly that the “speed” from the 4080? I assume that the Graphics cars has to do a lot less “communicating” with the RAM memory when it has more Vram. On the topic of RAM, does MHz play difference while working with big files ?
Bonjour, alors oui, et oui !
Oui La VRAM passe en priorité et déleste la RAM . Donc 8 Go de plus ça compte.
Oui Les MHZ de la RAM comptent : 3000Mhz ou 3600Mhz +25% rapide Benchmark.
Et OUI OUI OUI la 4080 avancera bien plus que la 3090 ! Surtout avec l’évolution de D5 qui certainement exploite déjà et exploitera encore plus dans le futur les capacités des série RTX4000 !
Generally we recommend that the MHz is not too high, it has impact but not absoulty.
Thank you for your answer!
