Hello the team and users, does anyone know if there is a huge diference of performances when using d5 with an RTX 3080TI and RTX 3090 ? Anyone already tested both on the same scene? Thank you very much.
Hello, RTX 3090 is better than 3080, to be honest, 3080 is not very stable from my perspective…You can search in this forum, some users with 3080 posted they met crash/laggy problem, although this kind of problem finally can find the issue cause and be fixed (it is often related to overclock settings). And 3090 users seldom meet this kind of problem because 3090 can handle almost all kind of files.
But this year, the graphic card’s price will drop down, and maybe Nvidia 40xx gpu will come out, so you can wait for several months for better choices. Of course, this is my private opinion and a reference only.
Thank you Oliver, I’m gone have a look to the related post. However, the crashes happened also to 3080 Ti to ? cause when you look their properties 3080 ti and 3090 are quit similar…
Thank you for your answer
3080 ti user here - no issues with crashing for me
hope that helps
Hello, the probability of crash issue is very low, and of course, most 3080 users do not have that problem, as jowet mentioned. I think 3080ti should work well, and even if accident happens, you can let us know and we will help you solve the problem.
thank you all for your experience. I’ll try 3080ti first ;)…cheaper!
I am using 3080, there is a TDR issue at the beginning. You need to set the TDR time to a larger amount, etc. (Not sure, thats what the IT guy told me). After that, there is no more problem. I m happy with it ![]()
How much longer time didnyou configured? Please
