Rhino separate syncing per layer?
Can Rhino create separate links per layer, as in you do it with different object types in Revit?
Hi @lsong,
D5 does not yet support importing Rhino files with layers. The imported model will be a whole, if you need to adjust parts of the model individually you will need to import them separately. Thanks for understanding.
Do you have any plans for that? Is it feasible?
Posted in Ideas & Request.
Currently, D5 supports SU import with layers (up to two layers) and will continue to push for other modelling software’s features. Thanks for putting the suggestion out there! Very helpful!
Rhino always gets slower implementation unfortunately. Is that because the user base isn’t big enough for development resources?
We’ve also been working on the rhino plugin, and I think the syncing layers matter will take some time to achieve. Of course, thanks a lot for your suggestions.
