Revit - "Selected Categories to be Seperated" Greyed out
Having trouble with syncing Revit to D5. The revit models sync as “one object” and the option to separate categories in the export settings are greyed out. I am also using a trial for the Pro Version.
Hi there,
Are you currently using the D5 Livesync Plug-in? Please try to disable it first then proceed to modify these categories to be selected. You can only modify these settings before activating the Plug-in. Thank you.
