Hi all, let’s say I am adding a white trim material to a house, I need this on the eaves, columns, window frames, window trim etc. How can I use one material for all 4 instances, I don’t want to manage 4 different materials, just one master material is ideal.
Before you import your models to D5. In your modeling software, put same color/shader on all geometry, that you want D5 to color the same.
You can try to give these four models the same material in the modeling software and give them the same material name.
