I have 96 gb Ram With 12 gb RTX 3060 Graphic card.
Render time is 45 min for 9 sec video?
Lol, with rtx 3060 that’s fast enough, you can try with 30fps. If it’s Vantage or Lumion it will be 9 hours instead of 45 minutes.
Hi, if you have any doubts about the performance of your configuration you can download the Benchmark scene and compare the times with your own video card.
https://benchmark.d5render.com/
Regards
Hi there. The 60fps video rendering provides finer detail and smoothness at a cost of more rendering time and larger file size.
This still depends on the type of mood you want to evoke in your videos, 30 fps is best for traditional storytelling as it evokes a classic and timeless quality. A higher frame rate might not necessarily suit the mood and atmosphere. 60fps is best used for busy scenes with multiple motions, like athletics and action sequences, and is less versatile than 30 fps. So, it isn’t used as much outside these settings.
Higher FPS requires more time in rendering, so use it at your discretion
You might also want to turn on the D5 SR Image Beta widget, as this speeds up the rendering process at the cost of some minimal detail loss.
As mentioned by @JoeLouis, running the Benchmark tool is suggested, so you can test it further. Thank you
