Render speed
I have two computers at home. Before formatting my personal computer, both had the same render speed, it took approximately 1 minute to get renders in 2k.
Now after installing the program again, the rendering speed has decreased considerably, rendering a 1920x1080 image in 7 minutes.
I’ve never done any additional settings but will this have to do with proxies or something? please I need help
In addition, the calculation of the time each render takes is taking approximately 5 minutes.
It is an excessively long time considering that on this team a week ago it was done in seconds.
Hi @soporte2
Render speed differences are often related to hardware specifications or driver settings. Could you please let me know:
  • Are the hardware specifications identical on both machines (GPU, CPU, RAM)?
  • Is D5 Render set to use the high-performance NVIDIA GPU on both systems?
  • Do you notice high CPU or GPU usage during rendering on your current computer?
  • Does the issue also occur with small test scenes? Could you please try on a demo scene from D5?
  • Is the slowdown happening only when rendering in 2K resolution? What about other resolutions?
Could you also please attach a screenshot of the D5 system info
And Task manager hardware usage while rendering (if possible)
Thank you for your cooperation. I look forward to assisting you further.
