Hi denise, it seems the problem is related to texture streaming. Could you compress the scene file folder and send it to support@d5techs.com for testing and investigation?
Hi mate, can you try rendering it in D5 2.4 beta? I gave it a try and found that the effect should be better, although the snow decal texture is not very high detailed.
Join 2.4 beta: Discord
Hi Oliver, I finally found a solution to get around the problem with the blurry textures. I first need to import the FBX, texture it. Then transfer the .abc file from it. - Transfer the textures with pipette.
