I have install D5 render on C:
but my C: drive is full
when I open a big project even if it save on F: (my other drive )
there is some temp file that goes on my C: (40 Gigabit while open)
Question :
if I reinstall D5 render on my F: drive, will the temp filles will be relocate on my F: drive where I do have plenty of space
or no matters what you do the core temp will be writing on C: drive , (my document Appdata Roaming etc…)
Hi alek.gilot. Some time ago I had installed D5 1.4, which was in C, without thinking I reinstalled the program in F which was empty, because the size of the disk on my laptop was different, that is, C with 500G and the other F with 1500G, I organized F to install programs, work and more, the system responded well, but at the time of 1.4 I wasn’t PRO, when I became PRO, the updates automatically went into the F folder in ‘Program Files (F)’. However, I must say that in the hidden AppData reference folder there is a residue of the D5 1.4 program, which doesn’t cause me any problems, so I didn’t delete it. I must say that even when the updates arrived the program responded very well with a 16G GTX 1070 laptop, so this thing I tell you is my positive experience, now it is a decision that YOU have to make to work with peace of mind.
I WISH YOU GOOD WORK
Sorry for the English
When I open the project , it filed for 30 Giga bit in cache
When I load an FBX to convert in .d5 asset it take some cache , it seem to load all the texture,
as soon I close the project the 30 giga become available again,
C:\Users\a.gilot\AppData\Roaming\temp\Streaming
here from 16Giga to 30 Giga depend of the project,
when I close the projet the file “streaming” disappear,
the question is can I relocate this Streaming cache folder
else where on F (100 Giga free)
Hi there, Temp files created by D5 or any other program temporarily store information while a task is performed. Many programs, including D5 Render, are designed to delete temp files once they are no longer needed.
Thus, upon restarting D5, files in this directory will be automatically removed. If the D5 scene has been saved, the related files in the temp directory will be automatically transferred to the location of the saved D5 scene. As of now, we have yet to implement a setting or feature that allows users to modify the location of the temp files aside from their default location.
If you have not migrated your D5 WorkSpace folder to the larger storage, I suggest doing so. You can easily do it by:
