reloading a file from 3ds max source , makes my model dissapear completly in d5 !!!why tho ?
Hi, on the left there is a drop-down menu where there is the name of your file, click on it to see the properties on the right, see the coordinates and size of the object, then move closer to the top right where you can change the property of the object. The object is zoomed in when you select it. Try it this way.
i re-synched the file and everything is working now , all the already existing materials and surfaces which already got assigned with previous materials , got re-assigned correctly , and left me with the modified stuff i needed ! thank you for your quick reply
