Ver.1.6.1.0020
Release date: 20251016
New
- Supports SU2026
Ver.1.6.0.0015
Release date: 20250715
New (Requires D5 Render version 2.11)
- Supports syncing orthographic views.
- Supports syncing disc lights.
- Supports syncing HDRI files.
- Added quick access to Help Center.
Optimization (Requires D5 Render version 2.11)
- Optimized sync of top/front/right/left/back/bottom views.
Fixes
- Fixed the issue where models would disappear or jump to a distant location, previously requiring users to explode or scale them in SketchUp as a workaround.
Ver.1.5.0.0017
Release date: 20250319
New
- Supports SU2025
- Supports 2025 PBR Parameter Mapping
- Supports syncing geo and sky from SketchUp
Fixes
- Occasional abnormal crashes of SU2024
- Abnormalities in model coordinates and dimensions may occur when connecting for the first time.
- Fredo’s morphing frame stretching feature leads to slower push/pull syncing of basic blocks.
- Under some non-Chinese systems, if the installation path of D5 contains Chinese characters, the connection may fail.
- Some particular scenes-abnormal hide/show status of tags during real-time synchronisation.
- D5 crashes due to abnormal surfaces within the scene.
Ver.1.4.0.0017
Release date: 20241120
Fixes
- Fixed occasional SketchUp crashes caused by pushing and pulling models during linkage
- Plugin loading failure caused by configuration file issue (manual deletion of D5LiveSync.conf file required)
- SketchUp 2024 crashes when loading plugins on some Windows 11 systems
- In some cases, materials modified in D5 for non-group models are lost
- Fixed occasional SketchUp freezing caused by deleting models after disconnecting linkage
- Fixed occasional plugin errors caused by grouping components with images during linkage
Ver. 1.3.0.0035
Release date: 20240808
New
- “Single Sync” incremental update button
- Supports synchronizing model show/hide status when switching scenes
- Supports synchronizing model show/hide status when tag visibility changes
- Pop-up notification for abnormal texture information during the first linkage
Optimization
- Significant linkage performance improvements
- Remember the toggle states of Live Update and View Sync buttons
- Monitor the abnormal state of D5 and take action to either wait or disconnect in real-time synchronization
Fixes
- Slow disconnection from linkage
- SU2024 crashes from sync plugin
- D5 crashes after syncing from excessive SU components
- Slow loading or errors when opening scenes with many lights in SU2024
- Occasional linkage timeout errors with ‘connection abnormal’ messages
- Material loss during initial file synchronization
- Occasional abnormalities in other components caused by component updates
- Occasional mesh or material modifications fail during linkage
- Occasional model loss when entering or exiting a component during data transmission
- Continuous light data sends occasionally trigger default light selection in D5
- Incorrect display of exterior facade of the attached model when moving surfaces of this component in real-time
- Errors in linkage and export caused by hiding the default layer “unlabeled”
- Loss of material names when exporting .d5a models
Ver:1.2.0.0006
Release date: 20240419
New
- Supports SketchUp 2024
Fixes
- Fixed the issue of imported SketchUp models getting stuck due to incorrect root group information
- Fixed the issue of missing materials after synchronization caused by the non-existent drive where the Workspace is located.
Ver:1.1.0.0033
Release date: 20231214
New
- Supports export .d5a
Ver:1.0.3.0001
Release date: 20231020
New
- Supports SketchUp 2023.1.340
Ver:1.0.1.0011
Release date: 20230907
New
- Supports SketchUp 2020.1 and higher versions.
- Added progress bar prompt for initial sync.
Optimization
- Improved stability of live sync.
Fixes
- Fixed the failure of the plugin loading for the first time in some environments.
- Fixed the loss of models within D5 due to rapidly clicking to start sync multiple times.
- Fixed the model misalignment after sync in some scenes.
- Fixed the abnormal model coordinate positions after sync in some scenes.
- Fixed the inability to sync images imported from SketchUp in real time.
- Fixed the loss of models caused by disconnecting and re-linking during modifications within components.
- Fixed the issue where real-time changes to material within components do not take effect.
- Fixed the UV anomaly caused by modifying material within components.
- Fixed the loss of material caused by showing components after disconnecting and re-linking during sync.
- Fixed an error of abnormal connection that occurs when synchronizing scenes containing a large amount of grass material.
Known issues
- Live sync delay when synchronizing scenes containing a large amount of grass material.
- Use tags to hide items is not yet supported for live sync, disconnection and re-synchronization is required.
- Switching scenes to hide items is not yet supported for live sync, and disconnection and re-synchronization is required.
