Release notes | D5 LiveSync for SketchUp
Ver.1.7.0.0001
Release date: 20260106
New and Optimizations
  1. Added compatibility and interchangeability between models imported via D5 LiveSync and directly imported .skp files to D5 3.0.
  2. Supports parallel projection and two-point perspective for scene synchronization.
  3. Supports synchronizing proxy assets from D5 Lite.
  4. Supports installing D5 LiveSync for SketchUp for all users.
  5. Enhanced sync efficiency and stability for live sync.
  6. Optimized material display logic which first reads parent component materials when a SketchUp model face has no material applied.
Fixes
  1. Slow/stuck progress and crashes when exporting .d5a models.
  2. Sync time build-up when linking with the same scene after synchronization breaks for multiple times.
Other Notes
  1. Sync with D5 version 2.9 and earlier is no longer supported.
Ver.1.6.1.0020
Release date: 20251016
New
  1. Supports SU2026
Ver.1.6.0.0015
Release date: 20250715
New (Requires D5 Render version 2.11)
  1. Supports syncing orthographic views.
  2. Supports syncing disc lights.
  3. Supports syncing HDRI files.
  4. Added quick access to Help Center.
Optimization (Requires D5 Render version 2.11)
  1. Optimized sync of top/front/right/left/back/bottom views.
Fixes
  1. Fixed the issue where models would disappear or jump to a distant location, previously requiring users to explode or scale them in SketchUp as a workaround.
Ver.1.5.0.0017
Release date: 20250319
New
  1. Supports SU2025
  2. Supports 2025 PBR Parameter Mapping
  3. Supports syncing geo and sky from SketchUp
Fixes
  1. Occasional abnormal crashes of SU2024
  2. Abnormalities in model coordinates and dimensions may occur when connecting for the first time.
  3. Fredo’s morphing frame stretching feature leads to slower push/pull syncing of basic blocks.
  4. Under some non-Chinese systems, if the installation path of D5 contains Chinese characters, the connection may fail.
  5. Some particular scenes-abnormal hide/show status of tags during real-time synchronisation.
  6. D5 crashes due to abnormal surfaces within the scene.
Ver.1.4.0.0017
Release date: 20241120
Fixes
  1. Fixed occasional SketchUp crashes caused by pushing and pulling models during linkage
  2. Plugin loading failure caused by configuration file issue (manual deletion of D5LiveSync.conf file required)
  3. SketchUp 2024 crashes when loading plugins on some Windows 11 systems
  4. In some cases, materials modified in D5 for non-group models are lost
  5. Fixed occasional SketchUp freezing caused by deleting models after disconnecting linkage
  6. Fixed occasional plugin errors caused by grouping components with images during linkage
Ver. 1.3.0.0035
Release date: 20240808
New
  1. “Single Sync” incremental update button
  2. Supports synchronizing model show/hide status when switching scenes
  3. Supports synchronizing model show/hide status when tag visibility changes
  4. Pop-up notification for abnormal texture information during the first linkage
Optimization
  1. Significant linkage performance improvements
  2. Remember the toggle states of Live Update and View Sync buttons
  3. Monitor the abnormal state of D5 and take action to either wait or disconnect in real-time synchronization
Fixes
  1. Slow disconnection from linkage
  2. SU2024 crashes from sync plugin
  3. D5 crashes after syncing from excessive SU components
  4. Slow loading or errors when opening scenes with many lights in SU2024
  5. Occasional linkage timeout errors with ‘connection abnormal’ messages
  6. Material loss during initial file synchronization
  7. Occasional abnormalities in other components caused by component updates
  8. Occasional mesh or material modifications fail during linkage
  9. Occasional model loss when entering or exiting a component during data transmission
  10. Continuous light data sends occasionally trigger default light selection in D5
  11. Incorrect display of exterior facade of the attached model when moving surfaces of this component in real-time
  12. Errors in linkage and export caused by hiding the default layer “unlabeled”
  13. Loss of material names when exporting .d5a models
Ver:1.2.0.0006
Release date: 20240419
New
  1. Supports SketchUp 2024
Fixes
  1. Fixed the issue of imported SketchUp models getting stuck due to incorrect root group information
  2. Fixed the issue of missing materials after synchronization caused by the non-existent drive where the Workspace is located.
Ver:1.1.0.0033
Release date: 20231214
New
  1. Supports export .d5a
Ver:1.0.3.0001
Release date: 20231020
New
  1. Supports SketchUp 2023.1.340
Ver:1.0.1.0011
Release date: 20230907
New
  1. Supports SketchUp 2020.1 and higher versions.
  2. Added progress bar prompt for initial sync.
Optimization
  1. Improved stability of live sync.
Fixes
  1. Fixed the failure of the plugin loading for the first time in some environments.
  2. Fixed the loss of models within D5 due to rapidly clicking to start sync multiple times.
  3. Fixed the model misalignment after sync in some scenes.
  4. Fixed the abnormal model coordinate positions after sync in some scenes.
  5. Fixed the inability to sync images imported from SketchUp in real time.
  6. Fixed the loss of models caused by disconnecting and re-linking during modifications within components.
  7. Fixed the issue where real-time changes to material within components do not take effect.
  8. Fixed the UV anomaly caused by modifying material within components.
  9. Fixed the loss of material caused by showing components after disconnecting and re-linking during sync.
  10. Fixed an error of abnormal connection that occurs when synchronizing scenes containing a large amount of grass material.
Known issues
  1. Live sync delay when synchronizing scenes containing a large amount of grass material.
  2. Use tags to hide items is not yet supported for live sync, disconnection and re-synchronization is required.
  3. Switching scenes to hide items is not yet supported for live sync, and disconnection and re-synchronization is required.
Hi, timing for the Sketchup 2024 version ?
thanks
Maybe in 1-2 weeks. :heart_hands:
Hi, still no update to SKP 2024 version - how much longer will I have to wait?
Hello, the new plugin is now live, please update it from our official website.
Hi , when the livesink for sketchup 2025
Hi @francosd You can join our discord server through the link to access the beta version of the Sketchup plugin; D5 Render
Hi @LiaHuang it looks like the discord invite stopped working, is it still possible to join the server and get the beta version for sketchup 2025?
Hi @ida.interiordesignar
Hello
Here’s the link to the latest D5 LiveSync for SketchUp (1.5.0.0017) which supports SketchUp 2025. Feel free to download it:
https://d5converter.d5cdn.com/installer/sketchup_livesync/48f0e4898d404488b4bb8fa77effadb0/D5_LiveSync_Sketchup_usa_1.5.0.0017.exe
Hi there, I have downloaded 1.4.0.0017 but I don’t get the option to install it for SU 2025 - what am I doing wrong?
Hi @zonearchitects
1.4.0.0017 is not the latest version that supports SKP 2025. You can download the new plug-in version via this link or through our official D5 Render Website. Thanks.
thanks very much. that has worked perfectly.
