Release notes | D5 LiveSync for 3ds Max
Ver: 1.3.3.0055
Release date: 20260413
New and Optimization
  • Supports 3ds Max 2027
  • Axis switching settings are now applied globally
Ver: 1.3.2.0049
Release date: 20250715
New and Optimization (Requires D5 Render version 2.11)
  1. Supports syncing orthographic views.
  2. Optimized light mapping with support for disc light and temperature/brightness sync.
  3. Supports syncing IES profiles from Corona lights and Photometric lights.
  4. Supports syncing built-in environments, dome lights of Corona and V-Ray, and HDRI.
  5. Supports 3ds Max 2026 OpenPBR materials.
  6. Supports V-Ray versions up to 7 and Corona versions up to 12.
  7. Supports more material/texture nodes of V-Ray and Corona.
  8. Optimized material template mapping with support for Foliage/Car Paint/Displacement/Fabric/Subsurface Scattering templates.
Fixes:
  1. Fixed the material ID distribution logic for Corona floorgenerator.
  2. FIxed crash caused by sync of Substance nodes.
  3. Fixed the rotation of X-axis when importing camera tracks and views from Max.
Ver: 1.3.1.0003
Release date: 20250422
  1. Supports 3dsMax 2026
  2. Changed ‘Sync/Unsync structure of light component’ to global setting
Fixes
  1. Fixed abnormality that D5 plug-ins are not recognized when installed in Chinese paths
  2. Fixed the abnormality of exporting .d5a named in Chinese by machines in non-Chinese environments
Ver: 1.3.0.0002
Release date: 20241217
  1. Added single send option.
  2. Optimized memory usage during the initial linkage.
  3. During real-time linkage, the plugin will pause when D5 enters rendering mode but remain connected. It will resume functionality once rendering is stopped.
  4. Recorded user preferences for single send or real-time sync, defaulting to the last selection for the next linkage.
Fixes
  1. Fixed data anomalies related to instance duplication and group editing.
  2. Fixed occasional model position errors.
  3. Fixed an issue where .d5a models exported as groups had a default 90° rotation on the Z-axis and sync coordinate errors when imported into D5 (this fix requires D5 version 2.9).
Ver: 1.2.0.0007
Release date: 20241028
New
  1. Supports exporting with a 2-layer group structure
Optimization
  1. Optimized the layout of settings and export pages
Fixes
  1. Fixed the resetting issue of the cone angle and visible in reflections parameters for the VRay IES light(this fix requires D5 2.9 Version)
Ver: 1.1.0.0083
Release date: 20240425
New
  1. Supports 3ds Max 2025.
  2. Supports livesync of light sources.
  3. Added version update prompt in the Settings.
  4. Added custom texture resolutions in the Settings.
Optimization
  1. Enhanced the efficiency of material updates when livesync is enabled.
  2. Optimized lighting synchronization logic: Grouping and renaming lights in D5 are now unaffected by subsequent updates (requires D5 2.7).
Fixes
  1. Fixed the occasional crashes occurring during scene synchronization.
Ver1.0.1.0064
Release date: 20240109
Fixes
  1. Occasional crashes for 3ds Max during sync
  2. Occasional failure to pick up materials for some models sync
  3. Inconsistency between coordinate system conversion method and UI display in some cases
  4. Error popup when exporting .d5a thumbnail
  5. Too light text for light mode UI
Known Issues
  1. Instance Mesh:
  • After importing into D5 Render, materials of Instance Mesh will be unified and can not be adjusted individually.
  1. Group Instance Mesh:
  • Group Instance Mesh doesn’t support adjusting materials individually and will use the same material.
  • If you move or duplicate the models within Group Instance Mesh, the information of the original/instanced group will be randomly displayed in D5.
  1. Hide:
  • If the archive has a group containing multiple layers, you have to unlock the group to hide one of them. New groups created after the livesync are not affected.
