lately I´ve recognized, that reflexions of more distant models (in my case nature like trees, stones etc. which I´ve created with the scatter tool) aren´t visible in the reflexions of glass, mirrors etc. Which bothers me a bit because there is such the ugly ground material visible instead. Do you know about this problem and how I can fix it? I´ve tried it by disabling LOD as well as setting the cull distance to the maximum…also I´ve disabled super resolution and frame generation but nothing worked out
I´ve attached a photo where you can see what I´m talking about (the red marked area)…if I place the mirror even more far away from the nature, none of it would be reflected…thanks in advance for the help!
Hello, there is a limited range of reflective plants. The limited range is 200 metres for preview and 900 metres for render.
