Is there a way to reduce the opacity of the tree assets, i want to make the background more visible. If there is a method to reduce the opacity of a layer that would help too!
Hi @kjain112004,
D5 does not support semi-transparent materials for now, and there is no way to reduce the transparency of a whole tree asset or a whole layer yet.
For now, you can set the leaf as a foliage material, and then adjust the opacity intensity. The value of opacity intensity is 0, the material is not translucent, and the value is 1, the translucency is maximized. You can also try other ways to achieve a similar semi-transparent effect of one certain material in D5: use Cloth material template (without any opacity map) but give opacity. You can export channel maps and process it in Photoshop. Thanks for understanding!
