Raindrops on windows are tiny
I just started using d5 and noticed that turning precipitation on effects in very small raindrops on windows. I tried turning strength and ponding to max but still the raindrops seem tiny (need to get camera VERY close to window in order to notice them). Why is that?
I was wondering - should i import models in any units? I used centimeters to create my scene.
Hi, you can adjust the “buddle” to control the raindrops strength on windows.
I did! Still the raindrops look much smaller than in the picture you posted, please see below, it seems my camera is much closer to glazing than yours as well:
Hi! I don’t think the distance of the camera affects the size of the raindrops usually. Your problem may be caused by the particular angle and surroundings. You could try adjusting the angle of view. You can also send us your scene file to check if you wish. (support@d5techs.com, and please describe the problem)
