Hello, I just copy out the whole folder of the project. When I open the file in another PC, the video clip sequence is gone. Is there a way to ensure that exists back too, or no other way?
Hi @nasrul
Just to clarify — did you copy the entire project folder? The entire folder is required because if any subfolder or resource file is left behind, things like video sequences or other project data might not load on the new PC.
Also, are you able to open the project normally on the new PC, and it’s only the video clip sequence that’s missing? Did you transfer the file locally (USB / external drive) or via a cloud service? Thanks
hello Ela, I was using onedrive to copy and download from. But I have resolved it. I opened directly from onedrive, and saved locally, the files and scene appears back.
