Hi, I have encountered this problem while lounching program. I have done everything from “view details” link tutorial and It still does not work. I am using HP Victus i7-14650hx 16gb ram and 4060rtx. Does anyone have solution for this problem?
Hi there,
I apologize for the inconvenience this issue has caused. When running D5 on HP Omen and HP Victus laptops, there is a tendency for the integrated graphics to be called instead of the dedicated graphics card (D5 only supports reading from the dedicated graphics card), which can lead to abnormal usage of D5.
- Open OMEN Gaming Hub - Select ‘Discrete’ GPU mode in ‘OMEN Gaming Hub-Graphics Switcher’.
You may also want to check out this link, specifically Solution 2: Specific Laptop Model
