después de dar clic a crear me aparece una pantalla en el que sale cargando llega a 99% y se cierra la pestaña
tengo una intel i5 y 1tb
Hi @rabel.tapia
Thank you for reaching out. Based on your description, the issue where D5 reaches 99% loading and then closes when creating a new project is usually related to hardware compatibility, GPU configuration, or driver issues.
Could you please provide the following information?
A screenshot of your D5 System Info
D5 version you are currently using
You may also try the following quick checks:
- Update your graphics card driver to the latest version.
- If your computer has both integrated and dedicated GPUs, ensure D5 is using the dedicated GPU.
- Try a clean reinstallation of D5 to a different local directory.
Looking forward to your reply.
