Hi! I’m facing a lot of trouble when I need to render a floor plan using a top orthographic view. The render gets a lot of noise, the shadows all messed up. It simply doesn`t work! If I need a floor plan, all I cand do is raise my camera in perspective mode, change to something like 300mm and the render gets ok but is still wrong due to the perspective. There will be any solution regarding this problem? Nowadays I have to make the floor plan in photshop or render in Sketchup Vray.
Hi, @render.arqvision Sorry for running into this issue, For the time being, you can do this as well, by minimizing the FOV value in your perspective view and mimicking the top view. Adjusting its FOV to 2, see the attached photo for your guide.
Rest assured that D5 Render is doing its best restlessly to fix this known issue in future releases. Thank you for your patience and understanding.
May this temporarily help your needs.
