Problem with lighting settings when reopening a file.
I was rendering a project 3 weeks ago and had to reopen it. However, all my lights are misconfigured, some with different intensities and others completely facing different directions that don’t make sense for the project.
I followed the normal process of relinking the new file when opening D5, and even if I open it separately from SketchUp, the file still appears to have the wrong lighting.
Hi @contato14
Can you confirm the following:
  • Is this consistently happening on all of your files? Or is it only file-specific? Perhaps you can share to us the replication process? A video recording will suffice.
  • Which Version of the plug-in was used? Together with the D5 and SKP Version? Please send us a screenshot.
  • Where are these files located? Are they stored in your local path? Or in cloud storages/network path?
