Problem with importing scenes from scenes express
Hello guys! I’m a new user. I wanted to import a premade scene from the site to the program but it says that the file is corrupted, even tho is DRS format. I tried everything but it either says that or it doesn’t do anything. Is it because those scenes were made in an older version of the program?
If someone could help, I would really appreciate it. Thank you!
hi, instead of importing. try to open that downloaded file. if it opens fine. d5 will update objects if its generated in older version. then try merging that file.
Hello. Is it convenient to tell us which scene you downloaded? We’ll check it.
Also, please note that you need the full folder to open a scene. If there is only drs, then you will not be able to use the scene properly.
