I have a problem with an FBX file. I’m trying to open the file in the program, and everything loads, but when the program opens it, the file is empty. The program was updated to the latest version yesterday. When I save the file in SKP format, the program opens it, and everything works fine. How can I solve the FBX file problem because I prefer working with it
which modelling software are you using? After the import, did the FBX file exist in the object list on the left sidebar? When you select it in the object list, how does the size of the model show up?
The ArchlineXP interior design program allows me to export the project only to an FBX or SKP file for D5 Render to process. On the left sidebar, the FBX file was visible, the file size unknown… because I reinstalled the program, and I install old version now I have 2.3.4.0932 everything works on this older version.
thanks for the update. Are you using 2.6.1 before? Can you send this FBX file to me? I will test it in my environment.
yes i send you
thanks for updates, I have received the file and would look into it. ![]()
We want to assist you with this issue remotely, stop something like this from happening again. Please see your DM.
Thank you in advance. ![]()
