Hello everyone, I would like to contribute possible improvements for future updates, of problems that I have been encountering in the processes of realization of several projects.
1- Being able to use the clone tool with nature objects modified from the library and exported and added to local. The clone tool is only accessible with predefined nature objects.
2- Depth old Field, flicker and blur failure in very thin and close elements.
3- Select an object within groups without selecting the whole group. This forces to search for it manually within the group.
4- Water scale sometimes changes by itself when opening and closing a document.
5- More random water turbulence, not following a single pattern and direction.
6- Relationship between speed and distance traveled in cars. Wheels always seem to skid or do not turn as much as they should.
7- Editing properties within paths. Example: want to change the color of the leaves of a tree inside a path.
8- Being able to export other channels in video format, not only in png, exr.
9- Compatibility character 4d
10- Random flickering sometimes occurs in equally random areas with slight changes of light.
11- Some characters leave trails when moving, it seems to happen mostly if the camera is not moving.
12- Having several projects open at the same time.
13- To have a wider library of western characters.
14- Improve natural movements of characters.
15- Visible brush menu. It appears in inspector only if you select it and look for it inside the document, which makes it more complicated.
Thank you very much and best regards.
