Hello everyone,
How do I get the picture behind the glass of a picture frame?
I would like to replace the picture behind the glass with another picture.
Wasn’t there already something?
Bye
Andreas
Hello everyone,
Bye
Andreas
Hello. Are you using an asset from the library? If so, in this picture for example, you can select the material with a pipette and then modify the base colour map in the right menu bar.
If there is glass in front of the painting, you can press the alt key while sucking in a material to penetrate the material and select the inner material.
Thank you for the tip.
Works perfectly, with assets from the D5 library.
Bye
Andreas
It would of course be helpful if this were also possible with objects that do not come from the D5 library.
For example, it would be helpful if materials could be hidden.
Hello. The TIP to hold down the alt key to select the internal material works for all models, including externally imported models as well.
