People Png
Good morning
and I would like to have them as assets
But I do not know how
Thank you for your help
Hi, try with the Alpha Channel effect. Just go to the drop-down menu on your right, select the materials that are next to the color, click on it, a window will open so you can load the 2D letters. Be careful, the PIG background must be transparent so you can’t see it. when you load it into the Alpha Channel you adjust it so that it disappears, and you will only have the letter 2d.
I’ve found if you use of D5 2D people cutout and then use the material eyedropper tool on the 2D cutout you can replace the color map with your own people png . This will allow the png person to automatically rotate with the camera since it’s built into D5 2D people cutout . Hope this helps too!
