Path Tracing suddenly not available anymore?
Hello, so I was using D5 version 2.10 without any issues and suddenly now that I updated to 2.11 the pathtracing option and custom settings are gone. I don’t get any option to turn them on and I am stuck on the old GI. I just read the patch notes and it says AMD GPUs are no longer supported for real time path tracing. Why??? my GPU worked just fine in 2.10 and now I have to roll back to 2.10 and be stuck in that version since suddenly a feature was taken away. Will this be addressed in a hotfix?
Hi @piero.salazar94
Previously, there were several users who reported visual inconsistencies and errors with AMD and D5 Render. Our team has decided to temporarily disable path tracing (PT) for AMD users because the existing problems outweigh the benefits.
We can’t really give you a specific time frame as to when this will be restored but rest assured, we’re working on it. Thank you.
Same thing here. It was running perfectly in 2.10. I have an RX 6700 XT and I’m sad to know I can’t continue to enjoy this feature in 2.11. I hope there’s a hotfix soon, because waiting for the next update will be a pain.
Espero lo mismo… que le den lugar a los que tenemos tarjetas de video AMD
i am using NVidia gpu and its still not showing
Clov,
I have a AMD CPU, but a NVIDIA GPU and path tracing seems to be disabled. Is it any AMD hardware that will make path tracing inaccessible right now?
Hi @jay907p @lakeandlandstudio
With NVIDIA GPU, Path Tracing is enabled by default with the new update. Disabling this option will have PT disabled too.
Hi Clov,
Does it means that PT is on, but we can’t set it as before? what’s the settings automaticly applied?
Hi @atelierHKD
For AMD Users, PT is disabled by default, and for now, there is no option to enable it. As for RTX GPU Users, PT is enabled by default and enabling D5 Legacy disables it.
Hopefully there will be some goodnews in the next update about this issue~!
