Path Tracing Render Time increased significantly in 2.11
I am using the default precise settings for the render and 4K res. The renders took about 2-3 mins each. After the update they take about 10 mins per scene. Is this expected to be optimized or is this outcome due to the full release of PT?
Hi @doruk
Previously in 2.10, did you perhaps disable Path Tracing? If so, try disabling it in 2.11 and see if the render time is the same as the previous version.
Although there may be some increase in GPU utilization since PT is enabled by default, I don’t think it should have this huge gap between 2.10 and 2.11. You may also want to check if your drivers and Windows system are updated.
