Hi , I thjought it might be efficint if you added also interior Parallax material , not only Parallax planes , so that I can in 3dsmax populate my interior with planes ( which is mych faster ) then apply the material in D5 Render. Thanks
hi, interior Parallax material is different than typical plane surface property. that material is combination of six textures applied to 6 unique surfaces, which create depth. bit complex process . sharing link might help.
thank you for your reply , the idea was to use softwars like 3dsmax to populate the planes behind the window which is more efficient and faster , but if building parallax material in D5 is not possible , then it is what it is !
