Hi all - Can anyone help understand -
I’m trying to get an opal/white opac transparent material. I am struggling to get the white to run through the material. i’ve downloaded the frosted material from online assets as a starting point - if i lower the transparency D5 takes it to black - as you see I’m working with no sun light its a studio set up just spots and rectangluar lights plus emissive materials - my base material is white
if i do the same creating from scratch a transparent material - the same happens.
As far as I know this is not possible right now with the engine.
It will be improved in next version. We all have the same problem
with the transparency channel and colouring.
HELLO CMEED
I SOLVED IT SIMPLY BY PUTTING A WHITE PICTURE AND PLAYING WITH THE TRANSPARENCY, BUT I DID IT A LONG TIME AGO.
WITH AN OLD VERSION D5 THAT I DON’T REMEMBER WHICH IT IS, I GIVE YOU THE IMAGE THAT I HAVE ALSO POSED ON THE FORUM,
